2.4 Oil leak - Maintenance and Repair Forum
2.4 Oil leak
Thursday, April 06, 2006 4:25 PM
I don't know where to post this but I only have an hour so here it is:
2000 sunfire Gt stock used motor oil leaks out of dip stick and when engine is running air comes out of the dip stick hole it's no a lot of air not enough to blow the dip stick out, I don't know if it's normal or if something wrongs internally but I have no power lost just a little ideal problem idealing up and down, if anybody can help it'll be great appreciated
Re: 2.4 Oil leak
Thursday, April 06, 2006 7:39 PM
This is due to a couple of possible problems. One is definite is that you have what is called crank case pressure. And no this is not a good thing at all. What is happening is the more then likely your piston rings are letting pressure from the compression stock to leak by and then for pressurizing your crank case. This pressure will try to find the weakest spot in your motor to release it and so there goes your dip stick.
GET IN HOLD ON AND SHUT UP!!!
ASS GRASS OR GAS NO ONE RIDES FOR FREE
