When I open my door, I hear a clicking sound, when I close it, sound goes away. When I turn the key all the way nothing happens except the service light flashes rapidly.
The lights do not work, nothing works. I checked the ground wires, the battery seems fine, except I can't remove the positive terminal since the bolt is warped.
Anybody help me? 02 cavy non-eco 5spd
its a 5 speed.. try to push start it.. if it starts its the battery.
How do I "push start" it?
Well push starting it didnt do anything.
I'd guess the battery or that positive terminal that is messed up.
You can't outrun the radio.
Did you check the battery cells & battery voltage?
it could be the starter if the engine isnt trying to kick over. i just had mine done and thats exactly what happened, flashing check engine light and such... new starter made it all better
I am not getting any lights working or anything. My friend has had a broken starter before and he still got lights working and door chimes etc...
I don't have a lot of money, or any, to spend $200 on a starter. If I do get a hold of $200 i want to spend that money to fix the problem. Not buy a starter and oops still doesnt work, now I got no money to fix the car.
talk about weird it just started
i @!#$ around with everything in the car and it just started, mind you nothing worked but it somehow started, i left the key in for 10 mins.
And guess what, its doing this again, this time I can get it starting within 2 mins, but wtf is going on here. It goes from having no battery power (lights dont work, nothing besides a few lights on the guage cluster work) to the whole car working good.
I know I need a new starter since its not in the best condition right now, but it sounds like a bad ground wire or something. But if it was why does nothing work, then everything, and it keep doing this? After I run it, I start it up again, starts normal.
Hey i had the same problem with my battery bolt found I finally got it off by using a drill yep thats right just dont put a bit in it and close it over the head of the bolt (or whats left of it
tighen and unscrew as for the rest of your problems I dunno
