Removing 00 strut mount - Maintenance and Repair Forum
Wednesday, March 22, 2006 4:16 PM
How do you remove the top nut on the front strut assembly on a 00 cavy? 95-99 is easy cause I can get offset wrenches down in there but because of the shape off the metal on 00 I cant. Help.
Thanx, Matt
Re: Removing 00 strut mount
Wednesday, March 22, 2006 4:57 PM
Impact wrench. Do it while the car is on the ground so you don't just spin the strut shaft.
Wednesday, March 22, 2006 5:03 PM
When I was in a jam (no impact), I used a pair of skinny needle nose vice grips. Put the wrench on first, then used the vice grips to hold the strut shaft, and lucky for me it worked
Was a difficult procedure though.....
Wednesday, March 22, 2006 5:43 PM
There has to be a "correct" way to do it besides the impact wrench. Do they make a special tool or somethin?
Wednesday, March 22, 2006 6:04 PM
there is a correct way. you use a hollow ratchet on the nut and a regular socket and ratchet on the strut shaft
Dark for fear of failure
An inner gloom as wide as an eye and fermenting
Roiling hate
Death gripped my veins
Unveiling rancid petals
Flowering forth foul nectar
The space between a blink and a tear
Death blooms.-mudvayne
Wednesday, March 22, 2006 6:23 PM
i had it in the spring compressor when i did it. like they say, impact is the best.
Wednesday, March 22, 2006 7:13 PM
Where can I get a hollow ratchet?
Monday, March 27, 2006 10:29 AM
Different struts have different methods of securing the rod from the top and some, like the Koni Sports with the adjuster on top, have none at all.
For my Koni Specials, I'd put an impact socket over the nut and put an allen key down the middle of it to hold the rod, which has an allen socket on top. Then I'd use vice grips to turn the socket.
Ideally, you'd want a socket with a hex shape on top like most spark plug sockets have, but I've never seen any on sale. I know they exist, but never found any.
You can't put a wrench on the nut because of the shape of the mount. On other cars and, I think, on the 95-99 mounts you can do that, but not on these.
Impact wrench is really the best way to go.
