getting rid of play in B+M shifter - Maintenance and Repair Forum
Sunday, March 19, 2006 7:15 PM
Hello guys,
I would like to know one way, how i could get rid of my extra play in the shifter. Its very frustrating and i just want to have my shifter tight and firm. Please any information would be great. I have a 96 cav.
Re: getting rid of play in B+M shifter
Monday, March 20, 2006 7:19 AM
Call B&M. Tell them the problem and they should be able to offer a remedy.
Monday, March 20, 2006 7:20 AM
User a thicker upper O-ring. That took care of it for me.
Tuesday, March 21, 2006 9:25 AM
Hey wild weasel: where can i buy or find a thicker upper 0-ring?
Tuesday, March 21, 2006 10:15 AM
The shift mechanism is still cheap plastic... b+m short shifter or not. Sorry, but it's never going to feel like it's not a cavalier.
Tuesday, March 21, 2006 10:22 AM
You should be able to pick some up at any home depot. Check in the plumbing section for all sorts of O-rings. Bring yours along and fine one that's the same diameter but thicker.
Tuesday, March 21, 2006 1:18 PM
one more question, weasel: I would like to know how can i take out the o-ring from the shifter?
Tuesday, March 21, 2006 1:24 PM
listening in...
Goodbye Callisto & Skaši, Hello Ishara:
2022 Kia Stinger GT2 AWD
The only thing every single person from every single walk of life on earth can truly say
they have in common is that their country is run by a bunch of fargin iceholes.
Tuesday, March 21, 2006 2:05 PM
Have you made sure your cables are where the old ones were when you disassembled it?
Knowledge about everything and yet an expert of nothing!!
Jack of all trades.
Tuesday, March 21, 2006 5:20 PM
I have the same problem and its annoying....
bliZsham wrote:The shift mechanism is still cheap plastic... b+m short shifter or not. Sorry, but it's never going to feel like it's not a cavalier.
before i install the b&m there wasn't any play in the shifter like i have right now!!!!!!!!
Silver_00ZED24 wrote:Have you made sure your cables are where the old ones were when you disassembled it?
this is for 00+ getrag
Wednesday, March 22, 2006 6:57 AM
Rods or cables, you still need them properly adjusted. If you're having actual trouble getting into gear, then this is probably the issue. This isn't the issue for play though.
To get to the upper O-ring, take off the boot and take off the top retaining ring. To remove it, you'll need to turn it so that the tabs are oriented with the wide parts of the openings. Then use a flat screwdriver and just jam it into the tabs to release them one at a time. Once two are released, you can take off the ring.
Check out step 8 in the instructions here:
http://www.wildweasel.ca/j-body/HowTo/BMShifter.asp
That's what you need to take off. The instructions tell you to remove it from underneath, since the shifter is out of the car. You can easily remove it from the top as well so you can actually go to Home Depot... pop the ring off and take out your O-ring to take inside and find a match... then pop it back in when you get back to your car to leave.
Wednesday, March 22, 2006 1:20 PM
weasel: My shifter isnt out of my car. And for the pictures regarding step 8 on your site, which picture is the o-ring? What the duration of taking out the o-ring and putting it back in? Could you help me to better undrstand, how to take the 0-ring out.
Thanks
Wednesday, March 22, 2006 1:43 PM
ok, then how do i adjust them?
thanx!
Wednesday, March 22, 2006 2:34 PM
Sorry to thread jack but what type of grease do you use on the ball joint? I have a 01 Z and a fidenza short throw. Thanks!
Shawn M.
PSN ID: Phatchance249
Wednesday, March 22, 2006 3:09 PM
Dashaun Jeter wrote:weasel: My shifter isnt out of my car. And for the pictures regarding step 8 on your site, which picture is the o-ring? What the duration of taking out the o-ring and putting it back in? Could you help me to better undrstand, how to take the 0-ring out.
Thanks
I think you misunderstood me. The instructions say to pop out the tabs from underneath. They say that because at that point in the install, the shifter is out of the car.
What I'm saying is that you can also remove it from the top, while the shifter is still in the car.
When you pop that retaining ring off, the upper O-ring will be right there on top. You'll see it.
As for what sort of grease to use... I have no idea. It came with the B&M shifter.
Wednesday, March 22, 2006 5:02 PM
At least in Getrag and B&M (shifter and Trick shift) form, there is only a handful of cars that has a better feel then that combo. And trust me, I've been around with cars to make that assessment.
>>>For Sale? Clicky!<<<
Wednesday, March 22, 2006 5:06 PM
so how do i adjust them on my 97z?
Wednesday, April 12, 2006 8:38 AM
btw, there is no upper or ;ower ring on the shifter for the isuzu.... i dunno if i can still add one tho!
