I have a 1997 Sunfire and it is stalling at intersections and you have to babysit it when you first start it in the cold weather here in Canada. Any ideas what I should check or might need replacing?
I'd start off with a full tune up, including air and fuel filter, oil change, spark plugs, etc. see if that helps.
Desert Tuners
also check the throttle body gasket or the upper paneum gasket whichever ur car has
A real fukin engine
A real fukin sports car
I agree with Jarett, try a full tune up and filters first using GM parts. Any codes or other symtoms? Good luck
