Friend blew his head gasket... 96 2.2 - Maintenance and Repair Forum
Sunday, March 12, 2006 1:09 PM
My friend's thermostat stopped working and the engine was over heating and it blew the head gasket. when i took a look at it, it had exaust smoke coming from the driver side part of the headgasket. when it heats up it will start blowing oil out of it. i didn't notice the exhust smoke if there was any. I dont know if the oil is getting through the piston into the combustion chamber. but i think it is. should i get a used motor from and auto wrecker (100+) or should i get the head gasket and get it machined? (300+)
It's also an automatic transmission so would it be harder to pull it all out than a 5spd?
for the replacement of the head gasket, I have a few questions...
what happens with the machining process? can the bolts to come off on the head?
how much time would be expected to finnish the job, if i get it machined?
I tried searching but i only cam up with a few search results that only said "it takes a day or a weekend at most" and the prices and what needs to be done if i do.
Re: Friend blew his head gasket... 96 2.2
Sunday, March 12, 2006 3:03 PM
I would just get the motor out of the bone yard. All that hassel to get a 2.2 out, send it to a machine shop after disassembling it and draining all the fluids, wait for it to get done, pay more for it then a "new to you" motor, pay for a new headgasket, re-do the head gasket... (and yes, I know the headgasket replacement on a "duece duece" takes about 3 hours tops, done it a few times. It's still a messy pain in the ass)
Always helps to have spare parts laying around anyway with the old motor...
To be honest, I have never done an automatic, but I am sure it cannot be very difficult if you have done a 5 spd. Good luck...
Team GREEN
Suspension Division - "Handling Before Horsepower"
Making the turns since 1999
1998 EK Civic Hatch - Yes, it's a Honda.
Sunday, March 12, 2006 4:24 PM
The 2.2 is notorious for head gaskets, even the S-10 with the 2.2 engine. My local machine shop keeps like a minimum of 5 reconditioned heads on hand due to popular demand and sells em for $325.00. Thats not a whole lot more than what it would cost to machine/rebuild one anyway. If you do pull the head make sure to chase the threads in the block for the head bolts, and if all coolant is drained out of the block I would start it the first time with the thermostat out or get water in there somehow. My neighbor rebuilt his S-10 2.2 after the headgasket went and when he started it the first time he came close to overheating while the block had no water. Even started spark knocking from preignition until the thermostat opened up.
