2.4 problem - Maintenance and Repair Forum
2.4 problem
Monday, March 06, 2006 4:25 PM
My 97 Sunfire wont start, everything was fine, filled up the tank and went home, next day it started up then after I came back out of the house it was off. It will not start at all but it will seem to try for a second then nothing but cranking. Thought it froze, was cold when the problem began but it was 42 degrees yesterday. Any ideas? I did put in gas antifreeze after the fact.
Re: 2.4 problem
Monday, March 06, 2006 5:49 PM
it could be the fuel pump
Re: 2.4 problem
Monday, March 06, 2006 10:31 PM
fuel pump?
see if it hums wen u turn the key on
Re: 2.4 problem
Tuesday, March 07, 2006 6:13 AM
this should be in third gen with your other thread entitled 2.4 problem, double posting is the devil.
I would have to agree with maybe the fuel pump.
http://www.j-body.org/forums/read.php?f=1&i=333805&t=333704#333805
Re: 2.4 problem
Tuesday, March 07, 2006 9:28 AM
You have to determine if it's fuel or an ignition problem. Spray some starting fluid in the throttle body, if it starts, your problem is fuel related, if not, it may be ignition. Then, check for spark. Good luck.
