On my 98 z24 the power window switch (in the console) is missing the right button... It broke... The right side is fine, but the right window will roll down and will only go back up if i keep hitting the button over and over and over. THe left side on the other hand won't go down at all even if i push on the switch.... Would this be wiring? Switch? Motor? I think that the switch is going bad since the right side window will roll down but not roll up... Also on the left side (driver side) the power door lock switch only works when it feels like it... Could that be wiring? Could all of this be in the computer? or fuses? I checked all the fuses and they seemed fine.. Any help is appreciated
Sounds like you need a new switch and a new window motor. not sure abou the switch
