reverse lamps dont fire... - Maintenance and Repair Forum
Sunday, February 19, 2006 6:32 PM
I have a 5spd 2003 cavalier. I just realized my reverse lamps dont come on when i put the car in reverse. All i could think of is that its a blown fuse because i had taken my battery out a few times doing some work under the hood. Plus, there both out. Where/Which fuse is the one i should check?
Re: reverse lamps dont fire...
Monday, February 20, 2006 5:50 AM
Back up lamp switch.
Monday, February 20, 2006 6:01 AM
Where is that found?
Monday, February 20, 2006 6:33 AM
Monday, February 20, 2006 7:51 AM
oh, nice.
Cant these just be removed and cleaned up to work again?
Monday, February 20, 2006 8:25 AM
Its like $20.00 or $25.00 at the dealership.
Monday, February 20, 2006 2:40 PM
OK, well it was easy to get to and remove provided you have the right tools. I wish I knew that these things break like nothing under any tq. I broke my replacement, instantly with 1 quarter turn of the wrench, its made of the most brittle aluminum ive ever seen. Lucky that i got the threads out no problem.
If anyone plans to do this soon, make sure when you put the new on on that you dont use ANY tq. on the wrench once u can no longer get it tighter with your hand. I used the deep socket 19mm with no wrench, and just snugged it up with the socket by hand, its very very fragile.
Anyway its done. What a dumb problem to commonly have.
