I was wondering if anybody had this problem, when i roll my window up on the driver side, it seems to fall off track and at the top of the door, when it should go under the seal at the top, it goes on the outside of it instead. Do you all know how i can fix this? Thanks.
You need a wind regulator. Go to the junk yard and get one. Should run you about $20 from there. You go to the dealer and you will get raped.
Wheres and wants the wind regulator?
Sorry, meant to say what is a wind regulator and where is it.
ya wut the hell is that.
take your door panel off and check the track ect. you should find your problem there
