front end help - Maintenance and Repair Forum
front end help
Tuesday, February 14, 2006 1:40 PM
Ok i have been hearing a very harsh rubbing sound coming from my front drivers side so i figured my hub and berring was shot. I went and repalced the berring assembly to only find that the sound is still there i need some help some opinions maybe my cv boot? or the breaks? anything would be greatly helpful thanks
Re: front end help
Tuesday, February 14, 2006 1:54 PM
Hard to say. Did you check the brakes while you were there ? And if it were a CV joint its more of a clicking sound when you make turns then a rubbing sound.
Re: front end help
Tuesday, February 14, 2006 1:57 PM
well thats just it man it makes a clicking sound when i turn the wheels and a rubbing sound when i am driving i have a put in tokiko (cant spell) struts and h%r springs the strutrs made sounds b4 but it was a totally different sound.
Re: front end help
Tuesday, February 14, 2006 2:15 PM
Clicking while corning = AXLE. Dis-asemble like you did to replace the hub. But this time when you get the strut assembly out of the way give a good yank on the axle and it pops right out. ::: WARNING ::: The transmission WILL LEAK FLUID be prepaired for it with a pan under where the axle goes into the transmission. Once its out take your new one and slide it in and give it a kick good push and it will lock in place. Re assemble as you did with the hub. Replace any lost fluid and go for a drive and ppick up some beer.
Go home and drink them you are now done.
Good Luck and just ask if you need any help.
