Blower motor interchangeability - Maintenance and Repair Forum
Friday, February 10, 2006 1:25 PM
Am I correct to assume that all blower motors from 3rd gen J-Bodies (regardless of trim) are the same?
Re: Blower motor interchangeability
Friday, February 10, 2006 10:39 PM
I will back that assumption and raise it a "should be"
Saturday, February 11, 2006 8:43 AM
95 -00 is the same. 01 and up is a different part #.
BirdmanXXXXX!
Saturday, February 11, 2006 11:53 AM
they have different numbers but plug in and attach the exact same way so yes they are all interchangable
Saturday, February 11, 2006 11:08 PM
'verts have a different blade config, to push more air
1998 Chevrolet Cavalier
5-spd
Sunday, February 12, 2006 6:47 PM
i wonder if the 01 and up models have a better blower motor, because the 95-99 ones always go bad?
Sunday, February 12, 2006 10:54 PM
What usually goes bad is the resistor and some speeds cease to work itīs a sticky I believe
Wednesday, February 15, 2006 8:59 AM
Luis Baptista wrote:What usually goes bad is the resistor and some speeds cease to work itīs a sticky I believe
Correct. If that were the case however, I would only have the option of full/off. However, my car currently only has the speed of "off". I'm pretty sure the circumstances surrounding it's failure to work support my theory that the motor itself is bad.
As for everyone else, I managed to find a replacement cheap, so when it arrives and I get time, I'll plug it in to see what I can come up with...
