flasher relay - Maintenance and Repair Forum
flasher relay
Tuesday, January 31, 2006 10:15 AM
anyone know where the flasher relay is located??
my turn signals dont work, all the bulbs are good, the switch is good, the fuse isnt blown....so i got a flasher relay but the dealer wasnt even sure about it....
Re: flasher relay
Tuesday, January 31, 2006 11:09 AM
What year and kind of car do you have ? You don't say and your reg doesn't either.
Re: flasher relay
Tuesday, January 31, 2006 11:35 AM
Jackalope wrote:What year and kind of car do you have ? You don't say and your reg doesn't either.
its a 98 cavalier 2 door.....whats a reg?
Re: flasher relay
Tuesday, January 31, 2006 12:28 PM
98 cavi its under the dash near where the pedels mount. There should be a bracket that holds in.
Reg. short for Registration. you know where you filled in all the info about yourself when you joined. Like your dream car and that stuff. Well you don't have it filled in as to what kind of J body you have.
Re: flasher relay
Tuesday, January 31, 2006 12:42 PM
Jackalope wrote:98 cavi its under the dash near where the pedels mount. There should be a bracket that holds in.
quote]
and i should be able to find the relay right there? there is a plastic cover under the break switch, should beable to see the relay without removing or should i remove it and it will be under it
Re: flasher relay
Tuesday, January 31, 2006 1:40 PM
Sorry man I'm not looking at an actual car I'm going off where the computer from work puts it. And so far its never been wrong. Not saying there couldn't be a first time but i hope not. But thats the general area look around and you should see it. Or my computer is wrong in which case I'm very sorry.
I hope this helps you tho.
Re: flasher relay
Tuesday, January 31, 2006 6:31 PM
sorry to be stupid about this but I was just wondering if you maybe able to find me a picture of what relay looks like cause i bought one from the dealer but im not sure if its the right one.....cause i found a relay in the pass kick pannel but it dont look anything like the one i bought
thanks again friend
