hey guys i think i have a spider gear problem , i was just driving then i got into boost and all of a sudden my car was jerking and going crazy, then i shifted into second and the same thing happened but once i put it into 3rd it was ok . then trying to get up my drive way on the way home i put it in first and it did it all the way up the drive way. then i threw it and neutral and gave it a few revs to see if it would sound the same and it ended up sounding fine. so if you guys think it could be something else let me know and if its the spider gears can you tell me where i can get some and possibly where i can get some cnc machined gears for it thanks guys
it might be a problem with my map sensor cause i still have a 1 bar on it or it coudl be a coil so help me out please
sounds like its prob the map, doesn't sound like a tranny problem, check your wire connections to the tps also
it might be , a little while after the turbo went in i had autozone run the codes that were coming up and one of them was map sensor low amperage or something like that . i know that i will have to get a 2 bar map sensor because i run boost but it just struck me as weired to have these problems now . i have been boosted for over 1000 miles and now this
just took the car out and every time it acted up i just stopped the car and touched the MAP sensor and it went back to normal
i dont have the map sensor mounted could this be a problem
it wasent the tranny so i can breath better now
yea i would mount it, i'm sure it shaking around isn't good
