Gone through 4 blower motor resistors HELP! - Maintenance and Repair Forum
Thursday, January 26, 2006 11:29 AM
Like I said 4 now. Is there supposed to be some trpe of air filter in the duct work for the vent so that water cant get down to the blower? When it snows and I clean the car off then start it up you can hear the fan throwing a little bit of snow arround and all the resistor I have replaced are coroded from the water. I fixed the last one I put in yesterday.
98sunfire4dr
Re: Gone through 4 blower motor resistors HELP!
Thursday, January 26, 2006 12:32 PM
My second one (the one I'm on now) went out. I have no air being blown out on settings 1 or 2. I'm too cheap to fix it anytime soon since I plan on getting a "new" car in late May.
Although it does suck driving in winter with it like this.
Thursday, January 26, 2006 4:39 PM
TREVOR wrote:Like I said 4 now. Is there supposed to be some trpe of air filter in the duct work for the vent so that water cant get down to the blower? When it snows and I clean the car off then start it up you can hear the fan throwing a little bit of snow arround and all the resistor I have replaced are coroded from the water. I fixed the last one I put in yesterday.
does your dash rattle when u turn on your blower motor?...if your getting corroded from water clean your plenum drain may be clogged. its on your firewall
MY 2003 SUNFIRE 15.63@87.86mph
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
Friday, January 27, 2006 4:57 AM
so there is no air filter anywhere in the duct work.. I know some cars have them I thought mine may have been removed or something.
98sunfire4dr
Friday, January 27, 2006 4:26 PM
Well, best I can recomend is to seal the resistor in clear silicone caulk-thin layer, seal up the electrical conections, then drill a small (!) Near the resistor for water to drain out. Also check the front end, to. There probably is blockage in the normal drains in the intake.
Friday, January 27, 2006 5:05 PM
DartBaron wrote:Well, best I can recomend is to seal the resistor in clear silicone caulk-thin layer, seal up the electrical conections, then drill a small (!) Near the resistor for water to drain out. Also check the front end, to. There probably is blockage in the normal drains in the intake.
What drain in the intake?
Saturday, January 28, 2006 4:32 AM
I think he's talking about the drain holes in the cowl. I had this problem with a 1993 Cavalier (water getting into the passenger side floor) and leaves had clogged up the drain hole on the passenger side.
God bless America.
