check engine light again... - Maintenance and Repair Forum
Wednesday, January 25, 2006 11:14 AM
every time I put a new O2 sensor by the cat, I get the 0141 code! is it frying my sensors? what could be the problem?
Re: check engine light again...
Wednesday, January 25, 2006 11:51 AM
Could be:
Short in sensor or harness
Water in harness
Open 12v Circuit
Open GND circuit
Low battery voltage
Corrosion or poor mating to terminals or wiring
Damaged o2 heater
Damaged PCM
Wednesday, January 25, 2006 2:33 PM
Thanks....
but what should I look at first? how can I tell if the O2 heater is damaged?
My car still runs like a raped ape but I just keep getting a light.
Thursday, January 26, 2006 5:53 AM
Casey > wrote:
My car still runs like a raped ape .
The easiest way to check the heater circuit is to go to Autozone and hook the scanner up to the car. When the codes come up, it will also give a descrotion that scrolls across the bottom. If it says heater circuit malfunction, then that's your problem.
If that is the problem, you are gonna have to find out where the short in the circuit is, cause obviously it is not in the sensor. Then we get back to.
Water in harness
Low battery voltage
Damaged PCM
Thursday, January 26, 2006 9:49 AM
Stupid question but are you clearing the code from the computer? Good luck.
Thursday, January 26, 2006 11:20 AM
yes the code has been cleared several times. as soon as the computer makes one full circuit, which is usually every couple of days, the light comes back on.
Update : upon further inspection (after I hit a roadkill vermin) one of the wires to the sensor harness was damged. I haven't had a chance to solder it yet. could this be the short?
Friday, January 27, 2006 9:17 AM
Possibly. Go ahead and fix it, clear codes, and drive to see if the light goes back on.
