So i need the help of the org again. I cant get my car to the dealer until friday, so hopefully someone knows how to fix it.
I got some 3157 APC leds for my tails. I put one in, it did not light up so i took it out, replaced with stock bulb. SO when I get out of work later that day (10pm) I turn on my headlights but my dash stayed dark. Then I notice my tails were not on.
My brake lights work, just not the tails. I took back out the bulb and put it in again and still the same.Hopefully I just blew a fuse (which I cant check until Tomorrow), but does anyone have any ideas on what else it can be if not the fuse????
I'm pretty sure it's the fuse. On your fuse panel there should be something called "cluster lights" or something like that. Same thing happened to me, not because of replacing the bulbs though. My cluster and tail lights would go out but my headlights and brake lights still worked. I replaced the fuse and it kept blowing, turns out one of my amp wires was pinched against the car because of the box, weird I know. I would say it's the fuse.
