trans fluid check....wtf - Maintenance and Repair Forum
Sunday, January 22, 2006 6:15 PM
ok, 02 2200 4speed
went to check the trans fluid level. all I can find is the little red knob that twists off. and there is no dipstick on it. and when I put my finger inside I cant feel any fluid and all I can find is what feels like a small wire harness
I know I'm not that dumb, how the hell do I check the trans fluid level anybody........
Re: trans fluid check....wtf
Sunday, January 22, 2006 6:55 PM
trans fluid check
read like 4 posts down....that should help you
Sunday, January 22, 2006 7:18 PM
thanks
I tried the search function and diddn't have much luck
so what there saying is....that red knob thing I pulled off IS the drain hole?
I'll have a better look at it tomorrow in the daylight
Sunday, January 22, 2006 7:36 PM
Trans fluid doesnt go away. You can buy a car with 1 mile and not touch the fluid, at 100,000 it will have the same level.
Are you checking it due to a concern, trans slipping or something?
Sunday, January 22, 2006 7:41 PM
I know that. I baught the car with 59,000 miles on it. its got 62k now and if/when I go to change the filter I want to know I have a way to verify fluid level for refilling it
Monday, January 23, 2006 4:44 PM
it's a stupid system, but on the r/h side of the trans, where the axle shaft comes out, there is a small plug, it's a 11mm or 7/16 wrench, this is the trans fluid check plug, after you do you filter change, put in 6 litres of fluid in the trans where the red knob is, have the car on level ground, start it and remove the plug. you will have the proper level when fluid comes out that hole where the plug is, so keep adding until fluid comes out, reinstall the plug and you're done.
