When replacing the timing chain on the LD9 what all do you need? Chain, Tensioners, Guides.. What else and how many of each do you need?
well if you really wanted to you can just get by with the chain and reuse everything else......but for good measure and you want to replace everything then you will need the following
1. Timing Chain
2. Timing Chain Tensioner
3. Timing Chain Shoes/ Guides ( 4 )
4. Timing Cover Gasket ( if it's leaking )
5. Crank Seal ( if it's leaking )
Thats about it...........
