horn and cigarette lighter not working - Maintenance and Repair Forum
Monday, January 16, 2006 10:40 PM
well my horn isnt working no sound at all when i press down on it, and my cigarette lighter isnt working either
how can i fix tese?
________________________________________
Daytona Blue, Cavalier Coupe, 2.2L I4OHV
Re: horn and cigarette lighter not working
Monday, January 16, 2006 10:46 PM
check your fuses. at the end of the dash on the driver side is a panel. fusebox should be located in there.
Desert Tuners
Monday, January 16, 2006 11:12 PM
how will i know which fuse is for what, and how will i know if the fuse is dead or not?
Tuesday, January 17, 2006 8:38 AM
pull the fuse panel cover off...... theres a diagram of what fuse is for what..... I had the same problem over the sumer cause i was going horn crazy while running radar detector and chargin my cell at the same time.......
boost will be soon for me....
Tuesday, January 17, 2006 9:28 AM
if you look at the fuse, you'll see two metal posts connected by what looks like either a "Z" or an upside down "U". if those are broken, then the fuse is bad.
Desert Tuners
Tuesday, January 17, 2006 11:05 PM
^^ so if the metal ends are broken off that means the fuse is done?
Wednesday, January 18, 2006 2:26 AM
Desert Tuners
