RPM Limiter In Neutral/Park? - Maintenance and Repair Forum
Saturday, January 14, 2006 7:44 AM
Does my stock '02 Starfire have some sort of rev limiter? In neutral or park, the tach goes to 4,000 RPM and then backs off when you depress the pedal. But when you floor it in drive, the engine will wind right up to redline with no problem.
Still learning about the car - only had it for a month. WR
Re: RPM Limiter In Neutral/Park?
Saturday, January 14, 2006 7:55 AM
Yes, there is a limiter when you are in park.
**there is only one true love in my life... and my girlfriend has learned to live with it**
Saturday, January 14, 2006 7:56 AM
and when you are in neutral too.
Saturday, January 14, 2006 10:15 AM
Generally, yes, both in Park and Neutral. Usually around 3500 RPM or so. Not a good idea to hold it there for any length of time. The fuel is leaned out/cut off to keep the engine from reving. Problem is, it's also the fuel that helps keep the piston head and top of cylinder cool. You can eventually do damage to the piston head.
Saturday, January 14, 2006 9:30 PM
if floored, the limit in park or neutral is 4500 rpm
Sunday, January 15, 2006 12:48 AM
You're both wrong, it's exactly 4,000rpm. Read your owners manuals.
You're not supposed to sit in neutral or park and rev it. If you're trying to show off, there's better ways to waste your time
Sunday, January 15, 2006 4:36 AM
Oops!
That '02 Starfire is actually an '02 Sunfire. The Starfire was an Oldsmobile model. What the hell was I thinking?
Sunday, January 15, 2006 12:06 PM
hmm. i dunno but mine will go to 4500. did it ONCE, a long time ago. didnt read the owners manual. maybe my tach is inaccurate too. i wouldnt doubt the inaccuracy since when in park my speedometer also moves with my tach
