Map sensor spec for 2.4L - Maintenance and Repair Forum
Thursday, January 12, 2006 9:23 AM
I'm trying to diagnose my map, but I have no actual spec to compare at idle, load...etc
Does anyone have the voltage numbers or know where I could find this other than convincing the dealer to hand it out
Re: Map sensor spec for 2.4L
Thursday, January 12, 2006 2:13 PM
The sensor is 0 to 5 volts. It is also 0 to 1 BAR. Linear scale.
Thursday, January 12, 2006 3:41 PM
Ok but see the thing is I'm havening a problem with my car, I'm really sure it's vacuum related...I can't find any leaks, so now i want to diag the map to either faulty or good
By saying 0-5 volts..you mean like a o2 sensor, or is at idle a certain voltage between 0-5v ...ex: 2v at idle??
Thursday, January 12, 2006 4:05 PM
No, doesn't sound like you know how a map sensor works.
Lets say, a 1 bar map sensor, 1 bar is 5v, 0 bar is 0 volts, if the car pulls 9.8psi at idle (20in/hg), then your map sensor voltage would be 1/3 of the available volts, so 5-(5/3) is 1.666 volts.
Thursday, January 12, 2006 5:10 PM
Perfect..thats just what I was looking for, thanx
Thursday, January 12, 2006 5:27 PM
But it's hard to diagnose the map with a digital volt meter. You need an O-scope. Or oscilloscope. Or an analog volt meter to show the wave of volts as you increase the load.
Thursday, January 12, 2006 8:15 PM
True, but i have my fluke at work that has a scope...shouldn't be a problem
