what is this thing? - Maintenance and Repair Forum
what is this thing?
Wednesday, January 11, 2006 1:37 PM
might be stupid, and may have been asked before, but what the hell is this ?
its somekind of a filler cap that is attached to the airbox......
i have an 02 manual, so i don't believe its somekind of tranny fluid, unless i'm way off, and underestimated GM's way of building a manual tranny.
Could it be somekind of clutch fluid?
I also can't believe i never noticed what it was, and i've had the car for about a year.......
sorry for being stupid...............
wait for it... wait for it... NOW GO!! ---> '02 LS Sport <---
Yahoo IM : buzz122 AIM : buzz122cav
Re: what is this thing?
Wednesday, January 11, 2006 2:51 PM
You got a 5-speed? THat's the clutch reserve.
Be kind to dragons, for you are crunchy and taste good with ketchup.
Wednesday, January 11, 2006 9:49 PM
yes, if you'll notice it says "fill with DOT 3 brake fluid" it is your clutch master cylinder
Wednesday, January 11, 2006 11:04 PM
QUESTION::? say i wanna take tha airbox out where would yo uguys relocate the clutchfluid at!?!?!? i have an intake i bought off of ebay but i left tha bottom half of the box in there ....i bothers me me....and how do you take the box outt i got stumped!!!
Thursday, January 12, 2006 4:49 AM
To take the airbox out:
1. take the screws out of the drivers headlight, disconnect and remove.
2. Take the lower wheelwell panel out, there's several small bolts and some of the
pushin type fasteners. (look in front of the tire, it's the plastic part that goes under the nose)
3. The windshield washer jug is attached to the lower airbox, remove both together, from under the nose, there's a bolt that attaches them together. Remove it and they pop apart. (washer has wire plug, unplug. also hose - plug or you'll get a face full of fluid)
4. In a 5sp, you must do something with the clutch master cyl resivoir. Turbo Tech Racing has a bracket that attaches to a airbox mount or fab a small "L" bracket.
5. re-install above parts / new air system.
Hope this helps.
Thursday, January 12, 2006 5:55 AM
kEWL...........thanx guys...........
where is it suposed to say to use DOT3 brake fluid?
well, i guess that would make sense, cuz it is a hyrdaulic clucth. DUH. All my other cars have been cable clucthes..... ( didn't think about that until this morning )
Thursday, January 12, 2006 8:16 AM
Unless you're adding a cold air intake there's really no need to take out the lower airbox. I have a shortram and all I took out was the upper box that holds the filter. All I did was loosen the fuse box remove the intake tube and pull the air box loose from its mounts. Easy. As far as the clutch reserve, I had mine just hang there by the clip next to the master cylinder, but now it's attached to the strut tower. Some mount it to the firewall, some place, AEM I think, makes a mount that attaches to the rear grommet hole for the stock intake.
Friday, January 13, 2006 12:55 AM
[quote=W@RiO§pe3D]QUESTION::? say i wanna take tha airbox out where would yo uguys relocate the clutchfluid at!?!?!? i have an intake i bought off of ebay but i left tha bottom half of the box in there ....i bothers me me....and how do you take the box outt i got stumped!!!
zipties are your friend or if you feel like blowing some money u can buy an aem adapter
