Car shudders between 61 and 63 mph - Maintenance and Repair Forum
Monday, January 09, 2006 7:00 AM
My boyfriend and I changed over my steelies to his old rims. He never had this problem on his car, but for some reason I have it on mine. Whenever I hit around 61-63 mph, the car shudders really bad. It's only around those speeds. Any idea as to what it is?
Thanks for the sig, Blakout.
Re: Car shudders between 61 and 63 mph
Monday, January 09, 2006 7:02 AM
Are the tires directionals ? And are they on the correct direction ?
Monday, January 09, 2006 7:09 AM
When we put the rims on, we put each one on my car in the same place as they were on his.
Monday, January 09, 2006 7:14 AM
The tires are probably out of balance. I know mine would shake really bad at any speed above 70, could be the same cause.
Monday, January 09, 2006 8:19 AM
are they aftermarket rims? if so its probably because you need hub centric rings. either that or the tires need to be balanced
Monday, January 09, 2006 11:44 AM
get the tires balanced bc i dont even rattle unless i'm doing like 85+ thats on stock 15 steelies and POS tires
MY 2003 SUNFIRE 15.63@87.86mph
"A N/A ecotec is not gonna give Honda's and Mitsu's that much of a run for their
money unless their blown or bottle fed.GM is still smokin crack!"
~1QWKZ24
www.streetracing.org, 08/2001
Monday, January 09, 2006 12:24 PM
balanced for sure and possibly an alignment
Monday, January 09, 2006 2:21 PM
Thanks guys. I'm going to be ordering some metal rings and hopefully will get a chance to get in for a balance/alignment in the next week.
Monday, January 09, 2006 5:54 PM
if they are after market rims you need 57.1mm hub centric rings for it
Tuesday, January 10, 2006 10:05 PM
could be a broken band in one of the tires, that happened on my lumina, when id hit about the same speed everyday it would shake, till i got that tire fixed
