Motor crapped out!? sounds like it has a knock... - Maintenance and Repair Forum
Saturday, January 07, 2006 12:16 PM
well, i have no idea whats wrong with my 2200. i know its been needing a tuneup but it shouldnt have just given out like this. it started throwing a missfire in cylinder #1 code, and i could tell it was off....kinda like it was running on 3 cylinders, but once i hit about 3500 rpm it would kick in and run smooth. well, now the car doesnt even hit 20 in 10 seconds with the gas floored, and when i let off the gas it shifts really hard. also it sounds like there might be a slight knock from the motor, and its blowing some light gray smoke. i dropped in some fuel injector cleaner, and that still hasnt helped. also i changed out the plugs, wires, coil packs, and the ignition control module....SO WHATS WRONG!? if anyone can plz help me it would be awesome. should i try to get this fixed, or get a 2.4 i found for around $1200.
Re: Motor crapped out!? sounds like it has a knock...
Saturday, January 07, 2006 9:04 PM
can anyone help me?? it sucks not having a car!!
Saturday, January 07, 2006 9:19 PM
do a compression test, and look into electrical problems....
