ive looked my 2200 over trying to find a place to put a manual temp gauge on it does anyone know where i can put one at?????
I'd get an A-piller pod and put it in that.
no not inside ive got the interior gutted its a rally car i cant find a spot to put it in the block of the moter its self???
How are you going to see the gauge if it's under the hood?
the gauge its self will be inside... im talking about the lil heat element on the end of the cable for manuel gauge...it has a lil heat element with a nut behind it that treads into the block head or intake or wherever their is a water jacket i cant find a spot to put it at??
Lawls at SHOoff...
First of all, do a search, you should be able to put one somewhere depending if you want to do some machining or not...
Secondly, you are not giving enough info, you want us to help you, but your not helping yourself... some prior knowledge and you letting us know what fitting is on the gauge would be much more helpful.
![](http://img.photobucket.com/albums/v296/Xxway2fast4uxX/01%20cavalier/Cavalier%20Body%20Work%20January%202011/100_2439-1.jpg)
Dennis Privett wrote:the gauge its self will be inside... im talking about the lil heat element on the end of the cable for manuel gauge...it has a lil heat element with a nut behind it that treads into the block head or intake or wherever their is a water jacket i cant find a spot to put it at??
Do you have a drill and a tap of appropriate size?
There is a plug on the front of the front of the block, on the left of the oil dip stick.
Remove it and use the appropriate reducer and adapt your sender there.
