Need ur help about a cav pleaseeeeeee - General Forum
Monday, February 05, 2007 10:40 PM
Ok well i found a 97 cav z24 forsale in my area its white no rust or dents at all black inside perfect condition the only thing she said it needs a timming chain thats hers broke or it sliped off now she only wants 500 canadain for it..is it worth it to get or what..the cars got 235 000 kms on it normal please need infoooo
Re: Need ur help about a cav pleaseeeeeee
Tuesday, February 06, 2007 5:42 AM
i would think thats fair
Tuesday, February 06, 2007 6:30 AM
Breaking a timing chain can destroy the engine, can't it??
Tuesday, February 06, 2007 6:47 AM
if its an interference engine... i dont think it is...
Tuesday, February 06, 2007 8:18 AM
i'd be interested to learn how the chain broke, as weas said that could do quite a number on an engine. other than that, crap, for 500 bucks i say go for it.
Brian
Tuesday, February 06, 2007 11:28 AM
more than likely its going to need a motor put in it
Tuesday, February 06, 2007 5:05 PM
Does it come with a new head?
ASE Certified Techician
DaimlerChrysler Certified Techician
Va Safety Inspector
Member Of TECHNET Professionals
Member Option D Racing
Thursday, February 08, 2007 7:51 PM
Ok well quick question just did a compresson test on the engine and its 180 all 4 cyclinders..If it bent the valves would it still hold pressure like that or maybe i was lucky and just the timin chain is gone
Friday, February 09, 2007 4:42 AM
No if the valves are bent you would have no compression at all on that cylinder.
Va Safety Inspector
Friday, February 09, 2007 5:25 AM
I f the timing chain were broken there would be no compression
Friday, February 09, 2007 7:36 AM
Jon Morgan wrote:I f the timing chain were broken there would be no compression
wrong.
think about it... when u do a leak down test or "compression" test.. ur pumping air into the cylinders.
only 3 things could make that air bleed out of the cylinders on 2.4 twin cam:
1.) bent intake valve
2.) bent exhuast valve
3.) broken or not sealing piston rings
now, there obviously can be some variances... there could be a HOLE in a piston, there could be a peice of something stuck under a valve, or the dreaded hole in the cylinder walls from a thrown rod, but that would be hard as hell... most rods that throw go through the oil pan on a 2.4. there could also be something holding a valve open such as a broken camshaft or destroyed lifters, but im doubting that happened.
im saying that if it held the air pressure then it should be fine, and if it broke the timing chain, go ahead and fix the timing chain-it would also be a good idea to buy new chain stubber deals and a tensionor, and while ur doing it u might as well do up the head- grind valves and valve seats, and replace the valve seals.
i myself have never heard of a timing chain breaking on a 2.4, and i cant even fathum how it could happen other than just the high mileage and or somebody beating the absolute CRAP out of it.
Edited 1 time(s). Last edited Friday, February 09, 2007 7:37 AM
UFlip06 said it best: Just look underneath the engine and if you see big hairy balls it's a 2.4 Twin Cam, if they're shaved it's an Ecotec and if you see nothing it's a 2200!
Friday, February 09, 2007 5:52 PM
I would get a price on the timing chain and what it's gonna cost you to fix the car before you buy, that doesn't seem like a bad price considering how clean you say this car is.. also I would check into the head gasket, cars those years can have problems in those areas and with the mileage it's probably getting close to the time to replace it...
Friday, February 09, 2007 8:05 PM
Im jsut going to do the chain its 240 for the chain and not that hard to do...question soo is 180 psi all 4 cyclinders good for the 2.4
Saturday, February 10, 2007 6:10 PM
i took everything off and the timin hoiles and everything match up and now im told my top end isnt gettin oil prob
