Since it seems nearly impossible to find a set of used 03 - 05 LSS Skirts
i need a set of sideskirts that are flat on the bottom. Ive ruled out 95 - 99 sunflower skirts as they are too short and stock looking. my 95 - 02 Z skirts suck because of the retaining brackets are easily broken on a lift and when they do, there is a notciable gap between the car and the skirt.
Import Fighter skirts have been suggested...
I've also noticed Wings West Type W skirts, does anyone know if the bottom is flat?
i only want a urethane skirt, there is nothing fibreglass on my car and i'd like to keep it that way
EDIT: also can someone get me the P/Ns for the 03-05 LSS skirts... i wanna see what i can get them new with my GM employee discount
Edited 1 time(s). Last edited Monday, March 01, 2010 6:16 PM
i don't be live the WW skirts are completely flat
Evo 5 sides? They're a reasonable facsimile of the Xtreme tuner sides, I'm sure you seen those.
2003 Cavalier Black Base, 5sp. Enkei Evo 5's in Hyper Black
blakcvy03 wrote:Evo 5 sides? They're a reasonable facsimile of the Xtreme tuner sides, I'm sure you seen those.
and they are also fiberglass. so those are out of the question.
azncav wrote:blakcvy03 wrote:Evo 5 sides? They're a reasonable facsimile of the Xtreme tuner sides, I'm sure you seen those.
My bad thought they were Duraflex, which I thought wasn't fiberglass.
Negate that whole previous post. I'm an idiot.
Search came up with this:
Skirt # thread
Should be what you're looking for.
Part #'s LH: 88952209, RH: 88952208
will 04 skirts fit on my 00 cavy?
xtremepimpin wrote:will 04 skirts fit on my 00 cavy?
From the sticky:
Third Generation Info:
6) Side skirts are interchangeable between sunfires and cavaliers.
7) Some side skirts are interchangeable between 4door and 2door jbodies (ex. Importfighter, z24, buddyclub 2, anything that does not flare up at all)
I would assume so, unless somebody speaks up otherwise.
blakcvy03 wrote:Search came up with this: Skirt # thread
Those show as the Sedan P/N, i couldnt find the coupe ones in that thread. I wonder if there is a difference
yes and way better than the 00 Z skirts
Edited 1 time(s). Last edited Monday, March 01, 2010 9:34 PM
If the sticky reads true, they will fit as they don't stick up any. I can't imagine they would make two different sets of side skirts, seeing as how much fits between the two. And, according to the dealer brochure, wheelbase is the same between coupe and sedans. Can't see how it wouldn't work.
alright... i didnt know if the wheel base was different or not. i'll see what my price and make a decision from there... thanks!!
wings west sides are technically straight, but have a high/low towards the rear. nothing to crazy tho:
WiGM-Tuners member.
welll what im worried about is under the car. Many years of careless tech's putting my car on a lift has damaged my Z skirts, and even when i try to lift it and im careful it still flexes a little bit. So i'm looking for a skirt that is flat down to the pinch welds.
GME Chat User: Speedline02 wrote:blakcvy03 wrote:Search came up with this: Skirt # thread
sedan and coupe are most likely the same.
you can actually us a DS on the PS and vice versa since they flare out in the middle and then taper back to original size at the end.
WW skirts don't bolt on under the car!
WiGM-Tuners member.
so just on the sides and under the door sill? got a picture of the mounting points?
GME Chat User: Speedline02 wrote:alright... i didnt know if the wheel base was different or not. i'll see what my price and make a decision from there... thanks!!
2dr n 4dr wheel base different,
4dr has no spot in the rear base to screw into...
I took it straight from the dealer brochure:
Wheelbase (104.1 in.) and Overall length (180.9 in.) is the same for the both the coupe and sedan, 2003 model. Overall length may be different, but I doubt wheelbase changed from '00 to '03-'05.
no pics, but the front and back mount in the inner fender. the sides are taped along the bottom edge!
WiGM-Tuners member.
