ok know this is a bit older than the norm:
Want to put body kit from 1990 Z24 on my 1993 VL (cs)? Possible?
The donor car is 2-door, coupe hatchback Z.
My car is 4-door, 6-window VL model.
Same generation wonder if body style make a difference.
Anyone out there with bit o' knowledge, Thanx
It can be done, yes. You should swap over the headlights, though...Ph1 kits dont look right with Ph2 headlights...you will need to weld or bolt on the brackets that hold in the lower skirts, and drill holes in your doors to fit the upper skirt...
