i have a 99 z24 with the 2000 headlight conversion. i'm replacingmy fenders and was wondering if i should get 99 fenders or 2000 plus fenders. would the 2000's bolt right up so there is no modification to be made, as opposedf to the 99 where there r mod's to be made. basically which am i better of with
yea the 2000 fenders are direct bolt on, instead of buying new fenders just cut the corner bracket off of your 99 fenders save alittle money
if you have the 00+ headlights now go with the 00+. fender looks identical just dosent have the bracket on the inside for the 95-99 corner light.
like he said you dont have to replace your fenders to do the headlight swap, i was assuming that yours were damaged or needed to be replaced for some reason
95-05 fenders are the same
