I have seen a tail-light bezel in carbon fiber for my 2005 Cavalier. Does this fit over the red-reflector one now or does is completly replace it. I am trying to black out my car and not with carbon-fiber
it replaces it entirely..........if your trying to black out the car, just paint the reflector, after masking off the reverse lights, or cover it in vynal
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
Do the back-up light remove from the red-reflector? If so how, I looked and did not see how?
It is all one piece (ie. the red reflector and back-up lights) the bezel replaces the red reflector part ONLY...reason being that you need 02' or older tailights(inner and outer). They are a direct bolt in on the 03+ cavs as well.
so I would need, the tail light and backup light assembly
yes if you want to use the cf bezel you need to get these....
or a set of aftermarket tails (euro clears, cf euros) will fit as well but imo took cheap and tacky. Also toyo tails would look nice. Either way you hafta buy some sort of tails to use the cf bezel.
