painting car... need help quickly please... - Exterior Forum
Friday, July 22, 2005 4:45 PM
Ok... i'm going to primer my car... i ran into a problem with the paint not being able to shoot out of the gun...
what i'm wondering... is if paint "REDUCER"... is the same thing as paint "THINNER"... are they the same thing just called 2 different words... or is there actually a difference...
cuz I'm using THINNER right now so i need to know if thats what jammed up the gun... please help me... lol... thanks alot
Re: painting car... need help quickly please...
Friday, July 22, 2005 8:00 PM
Finaly gonna paint that multicolored rainbow? lol
JHound
I took a Grey Hound bus to the 2005 GMSC Bash
http://memimage.cardomain.com/member_images/9/web/501000-501999/501209_5.jpg
Friday, July 22, 2005 8:13 PM
yes there is a difference, and yes that is most likely why your gun isnt spraying. I need a bit more info to help you out more though, like what kind of paint are you using? what type of gun? and are you going to base coat clear coat it, or single stage it? Ive been painting cars for about 10 years now so i will try to help out in any way i can. Most paints will require a reducer which will be teh same name brand as the paint your using because they will mix together better, thinner is often used more for cleaning and in some house paints, not acryllic enamel auto paints. Also your gun should have air pressure adjustments on it so when you get yourself some reducer play with those a bit to try to get yourself a nice spray pattern that covers well. My gun has an air pressure gauge on it and i usually shoot at about 3-4psi for paint and about 3psi for clear coat, just let me know, ill try to help boss
Saturday, July 23, 2005 8:23 AM
What size needle is on your gun? You said you're going to prime it right? Not paint? The primer guns we use have a 1.8 needle... most guns come standard with a 1.4 or a 1.5.
What type of primer are you using? Usually you do want to use a small bit of reducer with your primer to get it to spray better. Usually it will say on the can of primer what ratio to use... whether it's 3:1:1 or 4:1:1 (3 or 4 parts primer, one part activator, one part reducer)... or sometimes it'll have a percent like 3:1:10% or whatnot.
Saturday, July 23, 2005 9:24 AM
well i sure hope he`s not using laquer primer or enamel primer opps!!!!
dude today`s product never ever use thinner for a reducer wtf are you doin wrong!!!
it almost sounds like the material hardend in teh gun...l.ol....and if it`s on the car gotta to get if off need to explain what product line you are using so i can help more
can i haz bondo
