Hey guys I jus ordered the Hahn StreetHeat intake manifold w/PortFueler option & to my understanding the PortFueler is an amazing fuel controller but im wondering, from a few of you guy that may have it already, what are you using to control spark & timing? My assumption would be HP Tuners but i wasnt sure so I decided to ask. Thanks
It beats a Honda!
Use the port fuel for fueling, use HPT for spark control.
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
I've been working with this also, been trying to find ways to log boost in hp tuners using a seperate map sensor but just for logging purposes, still learning the spit second software
you should be able to log boost in hpt with a separate map as long as it outputs 5v and you have the pro version of hpt.
Sponsored by:
Kronos Performance
I do have the pro version, however finding the pigtail or voltage chart for a 2.5bar map hasnt been easy
Also cant use the stock one since its only a 1 bar, doing a fake 2 bar seems quite redundant if you have the portfueler
I'm just running HPTuners as you said to control spark. I have extremely limited resolution which is unfortunate, as I have to use one cell value to map the spark for 0psi-11psi for a given RPM. It's not that bad, but there's extra power to be found if you can do spark alternatively. With that said, it runs great and I'm fine with the minor spark inconvenience... the Portfueler makes life so much simpler. Just watch out for gas leaks, it took a while to get it just right on my system.
" To study and not think is a waste. To think and not study is dangerous. "
Hey guys keep me informed on this subect if you dont mind because im a complete novice on tuning. & i want to not only have the best tune possible but i would love to learn what the hell im doing in the process.
It beats a Honda!
