Can someone give me some help in getting Inj Duty cycle to log properly?
I have it set fo log but it doesnt pick it up?
Thanks
in your table hit insert, then under user defined the injector duty cycle should be there, after that you can add a guage for it
I did that but for some reason it didnt log it
Which sensor so i have to assign to the gauge when i create it?
I added the gauge with PID Inj Duty Cycle
My gauge isnt showing a Needle?
Im guessing that my Duty Cycle didnt log because i dont have a sensor assigned to the Table or the Gauge?
Edited 3 time(s). Last edited Monday, June 29, 2009 9:23 AM
You need to add the injector pulsewidths to the parameters being monitored, as well as RPM which is already most likely there. Once you are logging the pulsewidth, the Injector Duty Cycle PID will calculate the IDC based on PW and RPM.
-D
" To study and not think is a waste. To think and not study is dangerous. "
