hooking up wideband - Tuning Forum
hooking up wideband
Tuesday, April 28, 2009 9:55 PM
I just got an lc-1 wideband and i dont have hptuner. I want to know where to connect the brown (anolog 2) wire to the ecu and i dont know where to put it. Is there a other way with out splicing the wire going to the ecu.
Re: hooking up wideband
Tuesday, April 28, 2009 10:32 PM
Are you trying to replace your stock 02 sensor with the wideband? If not you don't need to hookup your analog outputs to anything.
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Tuesday, April 28, 2009 10:45 PM
how much more obvious could i make it?
http://www.j-body.org/forums/read.php?f=64&i=17008&t=17008
