check engine light code p0335 - Tuning Forum
Friday, February 27, 2009 8:01 AM
like the title says. 98 cavy 2.4 5sp. missfires and codes up only after 4000 rpms. anyone have diag for this code? does anyone know about the crank sensor recalibration? do you know if a snap on solarus would be able to do the crank recal?
Re: check engine light code p0335
Friday, February 27, 2009 2:51 PM
lyndon wixom wrote:anyone have diag for this code?
http://lmgtfy.com/?q=p0335
You need a new CPS.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
Friday, February 27, 2009 2:52 PM
You can try a CASE learn I suppose, but I doubt that will fix it, and a new sensor is like $15.
650 whp / 543 ft-lb
@turboalero
Friday, February 27, 2009 5:16 PM
