We changed the spark ramp out and fuel cutoff too 7,500. Take it too the track and it wont go above 6,500. Question do I have too change too a newer computer. Im currently running a 97 chevy cavalier z24 2.4L. thanks in advance
try maxing these tables....
Edited 1 time(s). Last edited Saturday, July 12, 2008 3:41 PM
rpm min-8,160?
enable vss-999?
disable vss=999?
Enable rpm=8,160?
disable rpm=8,160?
yep, just be careful and know when you let out of it..
this is just to see if it works til you find the real problem...
try editing the fuel cut table
thats your rev limiter.
DaFlyinSkwir(LS61) /PJ/ OEM+ wrote:try editing the fuel cut table
schmitzracing wrote:We changed the spark ramp out and fuel cutoff too 7,500.
for some reason some cars just dont get it the right way and need other things done... and being an auto or 5spd makes no difference.
"What do you mean by other things done"? The car is a manual everything is maxed out. May be go with a newer computer 2000 and up? Also we emailed hp too see if were just overlooking something. thanks for replys
did you try the traction control table?
z yaaaa wrote:DaFlyinSkwir(LS61) /PJ/ OEM+ wrote:try editing the fuel cut table
First I have heard of it.
z yaaaa wrote:did you try the traction control table?
yes, stilling shutting down at 6,500. we emailed hp they said the computer might not be able too store
much more memory. there gonna get back with us. the guy thats tuning it says he never ran into this
problem ever before!
