BCM cause HPT connection problem? - Tuning Forum
Thursday, September 13, 2007 8:45 PM
is it possible that a bad BCM or other module besides the PCM could cause a connection problem with HPT?
the HPT gauges work no problem. there are some DTC's, but I can't think of them off the top of my head, and I don't have the list in front of me.
Desert Tuners
Re: BCM cause HPT connection problem?
Friday, September 14, 2007 4:38 AM
what exactly do you mean by connection problem? are you not being able to connect to the car in editor? in the viewer? what type of problem are you having?
i cant see i bad BCM giving you a connection problem as it should have nothing to do with the actual running of the car. the BCM just controls things like the fog lights and the door chimes.
1997 RedR - ZedR
Friday, September 14, 2007 5:06 AM
we cannot connect to the car in editor, at the part where it says "gathering information". we can however get the HPT "gauges" to work.
Desert Tuners
Friday, September 14, 2007 7:14 AM
check all your grounds, and also wiggle the back of the ALDL.. I have a customer's car here giving me a similar fit...
P&P Tuning
420.5whp / 359.8wtq
Friday, September 14, 2007 7:40 AM
What kind of car? Year? Its not an S/C Eco is it?
Friday, September 14, 2007 8:41 AM
Also make sure only one program or the other is open. So either the scanner or editor not both.
Friday, September 14, 2007 8:53 AM
it's my LD9 to L61 Eco swap in my '02 Cav Z24.
we had issues tuning because we were trying to use an '02 tune I got off another member in an '04 PCM. we finally figured out about the PCM change in '03. I bought an '02 PCM from a guy on eBay. he programmed the VIN from the '02 tune I got off the other member into the PCM I bought off of him via a Tech II. and we're seeing the connection problem when it says "Gathering Information".
here's a link to the eBay ad:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ih=018&sspagename=STRK%3AMEWA%3AIT&viewitem=&item=280128708512&rd=1
Desert Tuners
Friday, September 14, 2007 6:16 PM
here are some codes we have been getting
[Restraints] B0036 - ADS Open/Missing/Shorted to Battery (History) (Immature)
[Unknown] B2662 - Unknown (History) (Current) (Immature)
[Unknown] U1128 - Loss of Communications with IRC (History) (Immature)
[HUD] U1000 - Class 2 Communication Malfunction (History) (Current) (Immature)
If I'm weird and everyone else is weird, does that make me normal?
-me
Versus Motorsports really @!#$ sucks
and so does DHL...but more
