Sip wrote:^ ^ HUH>?
The reason they 'don't produce any torque' is because they have comparatively smaller displacement. Good luck getting 200lb-ft out of a 2.0L block with no forced induction.
Jookycola wrote:my question is this. Honda makes fine cars, they're high reving motors are fun to run. but why can't they build anything with any torque?Well our 05 Honda Odyssey is rated at 244HP and 240lb.-ft........pretty good getup and go for a tank.
Evol...??? wrote:Well duh Jooky. didn't you know if you want better ft./lbs. of torque all you do is slap a turbo or supercharger on your transmission. that's why z24s have such high TQ stats, they have a little supercharger in the getrag transmission. jeez i though everyone knew that.
Thankfully Sip made (a little) more sense in his second post. yes the 197hp is rated at the crank and not the wheels. but that still does bot answer the question, the crank hp still does not determine the TQ specs of the transmission. for example the twin-cam LD9 is rated 150hp at the crank on an engine dyno as well and is still mated to a getrag transmission with 155 ft./lbs/ of torque. A much more well matched powertrain combo. so you don't need forced induction to get better tq, it's all how the car is geared. Now that, that arguement is defused we can now return to the original question. Why does honda build fast cars with no torque?
It's like they defiantly refuse to switch up their gear ratios to give their cars some grunt. I know that was the selling point of my Z24. I loved that "right there" power it had. It makes the car fell more sporty and fun i think. Does Honda have a reason why they refuse to up their Tq. numbers?
The current Civic Si with 200hp would be awesome if it had close to 200tq to match. They build cars with amazing motors that produce like 200hp, then give it a tranny with 120tq ...that's never made any sense to me.
Jookycola wrote: The current Civic Si has a 2 liter that produces 197hp, yet they have it very conservatively geared at 132 pound-feet of torque. 132!?
A 2000 Cavalier Z24 has more liters and more torque 2.4 - 150hp - 155lb-tq. Pretty evenly matched, The current Scion Tc is about the same. They could totaly slap a proper tranny with say...170tq on the Si and give it the "right there" grunt a so-called performance model should have. But they don't, It's a pretty simple question. Why not?
TSX: The small sedan will be redesigned for the 2009 model year. It may get the same turbocharged four-cylinder engine that is in the RDX crossover.
TL: A redesign is scheduled for the 2009 model year. All-wheel drive will be available. The new 3.5-liter V-6 engine is expected to put out close to 300 hp. A V-6 diesel may be available for the 2010 model year.
FCX: Honda's fuel cell car goes on sale next year as a 2009 model. The four-door is expected to have a 270-mile range. The interior features a biofabric partly made from corn. The car will not look like the concept FCX. Stephen Ellis, Honda's fuel cell marketing manager, says the company will market the redesigned vehicle aggressively.
Ridgeline: The mid-sized truck has not sold well but may be in a sweet spot because of new CAFE requirements. A V-6 diesel will be available when it is redesigned for the 2011 model year.
Evol...??? wrote:
Um...........right, anyways.
Tribals wrote:Jookycola wrote:my question is this. Honda makes fine cars, they're high reving motors are fun to run. but why can't they build anything with any torque?Well our 05 Honda Odyssey is rated at 244HP and 240lb.-ft........pretty good getup and go for a tank.
Evol...??? wrote:oh noes!
name calling?
so big of you.
Jookycola wrote:whoa, whoa, whoa.
i ran out of posts when asked that question.![]()
that's first time that's happened since i stopped being premium. It was not meant to start a flame war, i thought it was a good question. It had some good answers. I just thought an s200 has all that hp and kinda weak tq numbers and thought that was odd for a sports car. but even more odd, i had the chance to drive one this weekend and
