cavy trunk lid on a sunfire - Newbies Forum
Monday, October 17, 2005 1:06 PM
I was just down at a junkyard and picked up a cavy trunk lid to put on my sunfire.
the only part about putting it on, is will my sunfire's keyhole/lock fit into the cavy lid?
because the cavy trunk did not come with the trunk lid for some reason
http://www.cardomain.com/ride/2062967
Re: cavy trunk lid on a sunfire
Monday, October 17, 2005 3:42 PM
The trunk it self should bolt right on if it is a four door, and i dont; see why the key lock wouldn't fit either. They both use the same type of key, and if they are interchangable, then it should work.
I am what I am and it is what it is.
I am the 2nd most untrusted person in the world next to a lawyer,welcome to our dealership, may I help you?
Monday, October 17, 2005 4:47 PM
I guess you could do it but you basically already have a cavalier trunk...
Monday, October 17, 2005 7:49 PM
well i did it because then i get the inner tails, and dont have to worry about shaving the trunk bezel on mine.
it only cost me $20 and its the same color as my car already
Monday, October 17, 2005 10:03 PM
Hrothgar wrote:well i did it because then i get the inner tails, and dont have to worry about shaving the trunk bezel on mine.
Good deal then
Monday, October 17, 2005 10:11 PM
thats what i was thinking..
and while we're on the what i found at the junkyard subject - i also picked up a cluster while i was there, but then realized that it was a year older than my car.....will i be able to use it and work for my car?
Monday, October 17, 2005 10:19 PM
Hrothgar wrote:thats what i was thinking..
I don't believe there were major changes between the 1998 and 1999 Sunfires, so yes, it should work. How come you need another gauge cluster?
Monday, October 17, 2005 11:56 PM
when i put on my white gauge overlay, i pulled the needles off and screwed up my MPH, and my odometer doesnt work.
plus the brake light stays on now too.
so i asked what i should do awhile ago and was told to get a new cluster
Tuesday, October 18, 2005 12:11 AM
Hrothgar wrote:when i put on my white gauge overlay, i pulled the needles off and screwed up my MPH, and my odometer doesnt work.
Good reason
Tuesday, October 18, 2005 5:39 PM
for the key problem just swap the whole key lock piece. it's really simple.
as for the cluster, the only problem you'll have is with the digital odometer.
SO EVERYTHING!
Tuesday, October 18, 2005 6:33 PM
just as long as it reads a number i'll be fine.
i was told that i could get in trouble for it not working if a cop saw it
