Whats with the Sunfire hoods stickin alittle bit above the bumper??
I've never noticed this on mine...I will check tomorrow, but I'm thinking it might just be yours...
noticed it on 2 or 3 sunfires i saw
I kinda does it on mine...I'm not sure why tho...kind of annoying, but you get used to it.
it's a pontiac thing, just the way they're designed. i think it looks pretty decent
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
mine is a little high and has a bump in it from when i broke my strut and cv shaft
slide or die
What I hate is the dimples in the bumper by the joint with the quarter panels in the front.
in the mean time i suggest you check out
http://www.ratzero.com
for a forum where there are no rules, visit
http://www.emor8t.proboards41.com that is all.
Ryan Shissler wrote:Whats with the Sunfire hoods stickin alittle bit above the bumper??
there are 2 rubber knob things under the hood, They work like a screw level. Lower them and the hood will move farther down.
http://members.rankmyride.com/djtorello
I tried it and it doesn't work they are all the way down and it still stick up a bit and also when i try to shut the hood ill drop it to shut and it will only latch not shut then i have to push like helll for it to shut ??
Ryan Shissler wrote:I tried it and it doesn't work they are all the way down and it still stick up a bit and also when i try to shut the hood ill drop it to shut and it will only latch not shut then i have to push like helll for it to shut ??
I could never get mine to lock buy dropping it. I always pushed, Which is good practice if you ever get a fiberglass hood anyway.
Sorry, man, it worked for me.
