I just bought an ecotec engine(swap questions) - Newbies Forum
Friday, August 19, 2005 4:48 PM
I currently own a 2002 2200 auto Cavalier
heres my car domain link if you would like to see it
http://www.cardomain.com/profile/crda_jbody
I have been wanting to make my car stickshift for a couple of months now and came to realize it's a pain in the ass to do.
and if could be cheaper and easier if you just buy a hole other engine and swap it
So today i bought the complete ecotec 5 speed with all the wiring and everything
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7993669409
theres the ebay page i bought it from this only cost me $875.00
Anywho.
I was wondering when it comes time for me to do the swap is there any problems that I might run into?
or do i have weld new motor mounts?
and do I have to change all the wiring aswell right?
one last question will i have to move my exhaust sine the headers are diffrent
Re: I just bought an ecotec engine(swap questions)
Friday, August 19, 2005 4:59 PM
That's a nice purchase you got there.
I think the swap is basic like any other swap...like most people say, the wiring will be the hardest part.
If you need mounts, might as well purchase aftermarket ones...I have them on my ecotec and they are sweet. You can get them @ www.carcustoms.net.
Yes, you have to change the wiring.
Does this come with the computer from that vehicle also? If not, you need to have one specifically from a 5-speed ecotec otherwise you can't hook it up.
Does it come with all the shifter, shifter cables?
Also, you'll need transmission mounts...if your going to get some, might as well get aftermarket ones...also from the above site (I believe they sell them).
Friday, August 19, 2005 6:56 PM
yeah car comes with all cables and everythin it runs
Friday, August 19, 2005 7:01 PM
Daniel Alonzo wrote:yeah car comes with all cables and everythin it runs
Than you should be alright
Friday, August 19, 2005 7:18 PM
good luck with the swap
Friday, August 19, 2005 7:26 PM
you should only need to change the wiring in the engine bay since you have an '02, that means the BCM gauge cluster all inside wiring stays save for your your auto tranny stuff.
bottom motor mount is the same, upper will need swapped out, auto tranny mount will need to be removed, both tranny mounts will need welded in, you can get them at a dealer. the tranny swap will be your biggest challenge at the end of the day.
the only change to your exhaust will be be cutting out a section and moving it back so you can reattach it to the new manifold..
I'm pretty sure your life will be easier if you get the radiator out of that car too. the reason is that the main connectors for the Eco and the 2200 are reversed. the one up the other down, and vise versa.
Friday, August 19, 2005 7:28 PM
and check out EcoPower, there are some people there that have done the swap as well.
Friday, August 19, 2005 7:37 PM
Cinny wrote:you should only need to change the wiring in the engine bay since you have an '02, that means the BCM gauge cluster all inside wiring stays save for your your auto tranny stuff.
serious man thats going to save me tons of time
Monday, August 22, 2005 10:33 AM
Cinny wrote:and check out EcoPower, there are some people there that have done the swap as well.
where can i check on ecopower
Monday, August 22, 2005 10:46 AM
He's talking about ECOTEC Power the website:
www.ecotecpower.com
Monday, August 22, 2005 5:48 PM
^^^ thanks for the save Killa !
theres also a link at the top of the J-body.org pages too in case you ever loose your way. where am I again ? oh yeah now I remember.
Monday, August 22, 2005 8:36 PM
Cinny wrote:^^^ thanks for the save Killa !
It's no problem
Tuesday, August 23, 2005 3:26 PM
barely any one on that board
Tuesday, August 23, 2005 8:03 PM
so let me get this right
the only thing that i really need the change are the mounts on the transmission besides swithcing everything including the wires
how hard is it to just custom weld ur own mounts
Tuesday, August 23, 2005 8:08 PM
yeah but if your there too then theres one more
don't forget that the top motor mount is different too, but you will have that in the car, and it shouldn't be all that hard to weld them in.
Tuesday, August 23, 2005 10:13 PM
thanks
Wednesday, August 24, 2005 11:00 AM
if the donor car runs, couldn't you just make it a project instead of swapping? just an idea
Wednesday, August 24, 2005 1:55 PM
nope the car was fliped over
roof is messed up, i don't even want to try to fix that
that hold in the roof isn't suppose to be there that isn't a sun roof
no seats no doors no nothing
and it has some extreme body damage to the driver side panel
Monday, August 29, 2005 1:38 AM
The wiring is not that big a deal. When you pull the ecotec out, leave all the plugs attached. You should not have to seperate tranny from motor either. You already have the plastic gas tank I do believe so you wouldn't have a need in swapping that.
Obviously don't forget the pedals. You will need to drill the holes for clutch into the firewall as well. Instead of buying new transmission mounts/brackets you can also reuse the mounts from the donor car as long as you know how to weld properly.
I can't tell in the picture about ABS. If you have ABS and the donor car doesn't not, it's likely you will loose your ABS.
Josh
SLK 32
Monday, August 29, 2005 4:36 AM
why would he loose his ABS ? the engine is a different system.
Monday, August 29, 2005 10:33 AM
If he swaps to the donor vehicles braking system it may not have ABS. When we swapped mine, I went from ABS to non ABS.
Josh
SLK 32
Monday, August 29, 2005 2:51 PM
i was thinking it wouldn't be an issue because it's already a 2000+, the thing that would most likely differ to my knowledge is the brake booster. everything else you would have to change.
and since the wrecked car didn't do so well, you might want to keep what you have, lol
Monday, August 29, 2005 9:25 PM
um
Im going to sell my automatic 2200
it only have 22,000 miles on it
i was wondering how much should i sell it for
Friday, September 02, 2005 6:47 AM
anybody have an idea of how much in i should ask for
Saturday, September 03, 2005 12:14 PM
What you should do is basically swap the whole engine bay. swap over the engine cradle, rack and pinion, power steering, etc.
If you do this the trans mount will be right due to swapping the engine cradle.
I work at a GM dealership so I know that this would be the easiest way.
