some tune up info - Newbies Forum
some tune up info
Sunday, February 13, 2005 9:29 PM
well im thinking of doin a fluid tune up to my 97 Z w/ 2.4 l engine, not a newb to the engine, im jus trying to avoid ne flamiing that comes up, i jus wanna know the best ways to change the brake fluid, coolant, and trans fluid, from wut i hear,
trans fluid- take the pan off slowly
coolant- is there a drain plug like the 2.2?
brake-has to be sucked out from the reservoir
thanks
No better site in the world then a <a href="http://www.ntsearch.com/search.php?q=Honda&v=56">Honda</a> in my rearvieW
Re: some tune up info
Monday, February 14, 2005 2:52 PM
Brake fluid is a bit tricky because its a pressurized system, best way to learn get a haynes manual they have step by step instructions. Radiator is easy just drain and refill and same with tranny
Monday, February 14, 2005 3:27 PM
Pressurized? Huh?
The easiest way to change your brake fluid would be to just bleed it all out. Bleed each corner, adding fluid until it runs through clean.
