How can i take the steering wheel of my 98' cavalier with out blowing out the air bag. I looked around the steering column and i didn't see any screws. So i didn't @!#$ with it. (Can any body know how)
yea theres plenty of write ups. first you disconnect the negitive terminal on the battery and pull the air bag fuse. a steering wheel puller is required to remove the wheel.
where can i find a steering wheel puller at cant i just rip the air bag out and there should be a bolt holding it out isn't there. Cause i have another steering wheel to put on it
most parts stores sell or rent a puller
____________________________________
Primer Counts as Custom Paint Right?
BTW: This is my Sig.
are you putting a cavalier wheel back on? or going aftermarket?
you have a steering wheel hub right?
After removing the negative battery terminal, there are two bolts on the back of the steering wheel(10mm I believe).
I can post a pic if you'd like.
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
i forgot i had a steering wheel puller and bought another....now i have 2....doh. the only problem i had was removing that dang tilt wheel lever.
The tilt wheel lever is just a simple screw in piece. At least thats how it is on the 97 cavalier I have.
i had to use a vise-grip and just rip it off...sanded it down alittle to get the grooves from the vise off and put it back on.
There's 4 tabs in the back of the stock wheel that hold the air bag on man. After that's off the rest is simple. One big ass bolt to remove LOL.
5K PB: 24:50
10K PB: 54:26
I am having the hardest time on the final step the steering wheel puller. I stripped the smaller bolts and now I will be using a tap to make the holes larger to get the damn wheel off. It's on there pretty good and i'm tired of beating on it and yanking. I did see someone say they did not need a puller, I would like to see an example where it would have to be "hit" to not need a puller. Any help is appreciated.
FOR SALE
