fiberglass or paint ???? - Interior Forum
Friday, July 14, 2006 1:41 PM
this isnt me asking how to or anything I'm just looking for input
I'm fiberglassing my door panels but painting the dash under portion, and then glassing the top dash part in my 95 cav( if you can kinda get waht I'm saying) anyways if I sand and primer and get the bottom dash part smooth will it look alright with glassed doors and top dash part?????
anyone done that and it worked well/not so well please tell me
Re: fiberglass or paint ????
Friday, July 14, 2006 1:48 PM
yes
Friday, July 14, 2006 3:50 PM
Heres a picture of my girlfriends i did. Tore the vinly off the top and glassed it all one piece and then sanded the bottom portion smooth and primered.
Friday, July 14, 2006 5:32 PM
BlueSplash: I'm planning on doing that same deal this summer. But do you find your arms stick to the door panels without material in the way?
Friday, July 14, 2006 7:51 PM
thanks guys
Friday, July 14, 2006 8:38 PM
Yea a little but its no big deal. Good luck with it. Make sure to scuff up the plastic with 60 grit before fiberglass and drill holes.
Friday, July 14, 2006 8:47 PM
Yo, i just looked at your interior on car domain and it looks rrreeeaaalll nice... Whatd you sand with in between everything... or more then that, what was your technique and materials used for painting all your stuff?? Thanks
Friday, July 14, 2006 9:08 PM
zack bert wrote:this isnt me asking how to or anything I'm just looking for input
if you sand and primer and paint the bottom part the right way it will look just like the fiberglassed part no diffrence...
Saturday, July 15, 2006 6:16 AM
Basically sand all the texture off the doors or close to it with 220 grit. Use a 2k primer from an hvlp gun and primer it 4-5 times or until smooth after you wet sand with 400 grit. Degrease before and after sanding,primering and so forth. Lay 2-3 coats of base or till coverage occurs. 2-3 coats of clear then wait till ti dries and wet sand with 2000 grit then buff with 3m machine glaze that is a whiteish color.
Saturday, July 15, 2006 9:39 AM
Yeah its basicly identical except the fac that fiberglass weighs a ton and a half. I ended up doinf my while interrior with fiberglass and i gurentee it gaind like 200lbs. I would do whatblue splash said and just paint it...
http://www.cardomain.com/ride/2272113
Saturday, July 15, 2006 10:38 PM
Rob Kollay wrote:Yo, i just looked at your interior on car domain and it looks rrreeeaaalll nice... Whatd you sand with in between everything... or more then that, what was your technique and materials used for painting all your stuff?? Thanks
thanks alot most people dont like to color choice but I do I just sanded and painted once but I'm resanding and repainting same colors but makeing it smooth like a babys butt hahah
thanks for all the input guys
Monday, July 17, 2006 8:05 PM
did you sand the dashpad bluesplash??
Thursday, July 20, 2006 7:28 AM
When you did your door panels, did you fiberglass right over the carpet, or did you break off the plastic peices and pull it out?????
________________________________
never let anything slip away
