i already told u what my answer was
225x45 will keep your speedo the closest. if you go with the 235, you risk rubbing on the spring perch on the strut, unless you have coilovers.
Desert Tuners
![](http://i44.photobucket.com/albums/f47/Z24_FReQ/freqgtoyl7.jpg)
yea a 235/40 is gonna be a wide tire w/ a smaller sidewall. if i were you id stick w/ the 225/45/17
Save two pounds and get the 17x7.
Qwik2k2z24 wrote:17X8 with 225/45/17 FTW.
awesome setup i must say.
especially with the Trak-Lites. that was what I originally wanted, but didn't have the cash for them.
I wanted to go with a coilover setup too, so I could run a larger tire, like a 235 or 245.
Desert Tuners
Matt I know your buying this @!#$ for auto X.... just an FYI 225 is the bigest you can run in STS. anythign bigger then that are were back to the whole brake problem hahaha
I'd sa listen to Qwik2k2z24, thats what I would do.
