15 inch rims? - Wheel and Tire Forum
15 inch rims?
Saturday, November 12, 2005 8:19 PM
I have a 2002 Pontiac Sunfire with stock 15inch rims and stock 195/65/15 tires. the tires need replacing and i was wondering if i could go one size larger on the tire. I would like to put larger tires on it in hopes of making the car look bigger. so my question is how large of a tire could i put on stock rims and not have it rub or interfere? The way i have it figured, one size larger: 205/65/15 should work. tell me what you think. Thanxs!
Have Fun Kids!
Have Fun!
Re: 15 inch rims?
Saturday, November 12, 2005 10:44 PM
A bigger tire would throw off your speedometer. Trust me, Just get bigger rims or just go with the regular stock sized tires.
Re: 15 inch rims?
Sunday, November 13, 2005 10:33 AM
even going one size wider? from 195s to 205 only adds .22 of an inch with the equation i have. Seems like it would throw it off a very minimal amount?
Have Fun!
Re: 15 inch rims?
Monday, November 14, 2005 4:25 PM
a 205 65 would not work however a 205 60 will be perftect
Re: 15 inch rims?
Tuesday, November 15, 2005 4:19 PM
awesome! how much bigger would a 205/60 be?
Have Fun!
Re: 15 inch rims?
Wednesday, November 16, 2005 5:47 PM
those tires you first stated would work fine, dont let anyone fool you, trust me
Re: 15 inch rims?
Wednesday, November 16, 2005 8:38 PM
I am now running a 205 65 winter tire and it works. no rub but it slows my speed by 2.0 %
Re: 15 inch rims?
Thursday, November 17, 2005 10:44 AM
Actually, you can get even wider tires and at the same time be closer to stock rolling radius. 215/60/15s should fit fine—it's the widest you can go, but I've had no problem with it on Fiero 6" wide rims originally intended for a 195 tire. Plus, whereas with a 205/60 tire the speedo would be off a little over 1%, a 215/60 tire will only put it off by .7%—little enough that the difference will be more or less negated by other factors like tire pressure, when it comes down to the dynamic radius (tires as they are while you're driving).
Generally, you can oversize tires by up to 20mm—the main thing is keeping the sidewall height the same, which 215/60s will do great.
Here are some 215/60s:
http://www.discounttiredirect.com/direct/searchTiresBySize.do?sw=false&cs=215&ar=60&rd=15
Good luck!
Re: 15 inch rims?
Thursday, November 17, 2005 5:13 PM
i fit 245's on my car and its lowered... still fits
who cares about the speedo lol
"Growing old is mandatory. Growing up? Definitely optional."
Re: 15 inch rims?
Thursday, November 17, 2005 6:51 PM
hey guys,
thanx for the help. i was looking for people who have actully tried putting larger tires on their j-bodies. i think 215/60's will work too i am going to be putting monroe quic struts on my pontiac. that should actully lift the car a tiny bit because the upper mounting bolts are higher than stock mounting kit.
Have Fun!
Re: 15 inch rims?
Saturday, November 19, 2005 1:56 PM
I found this page to fix up all those curiosities about tire/rim sizes. just keep in mind what timothy said about trying to maintain rolling radius. And thank you timothy degner! 215/60's will work on my sunfire!
http://discounttiredirect.com/direct/brochure/info/tmpInfoTireMath.jsp
Have Fun!
