I need tighter steering! can i just put a smaller pulley on my power steering pump? Also my car is very loose on the highway past 75 mph. I likes to sway alot. i have a basemodel 05 cav. with 17*7.7 235/45/17 rims n tires. would sway bars help my problem?
Drop it, sway bars, grippier tires, etc.
your rims and tires sound fine, you've got a lot of grip.
rear sway bar, struts, and some lowering springs will get her nice and planted.
I've got, rear sway, KYB AGX struts, and a front strut bar. I've caught myself going 80 and the car doesn't feel any less planted than it does at 55.
-Chris
I've Got Potenza S03 Super grip tires..... And ive lowered it 1.2 with suspension techniques springs... I think i just need sway bars... On the highway it likes to sway Alot... it's got really good handeling but around some corners if i turn it to much it's like it totally gives out... it feels like it should be able to take it alot faster...
make sure your tires are inflated to the right PSI. should be about 35-37 lbs for 17"s
14.82 @ 97 mph
and usually if you want better handle... and no sway, than i would take
IAM RASCAL's advice and do
swaybars front and back. busshings..
i have eibach sportlines and agx's and a cambers kit, my car handles well.
im happy with it.
OEM CAMBER/CASTER KIT 10 People for $210 <P>
GOT ECOTEC?
