Just wondering.. if your going to run 19x8 in the front.. what offset should you go with?
35-45, the higher you go the more you're gonna rub on the inside front when turning, and the lower you go the closer its gonna be to lining up w/ the fender (in case you want tucking, etc.)
Okay so.... with that said...
What would be the best to use? With Air Ride system? like a 35mm offset or?
i believe it should be around 40 or so for air ride, I Think! so u can tuck.
pic coming soon
"Live Life To The Fullest" "Customize Everything"
I would run a 40-45mm offset if i was you. With my 18x8 with a 40mm offset they are awfully close to the fender and thats with a 1/2 inch of gap between the tire and fender. On the inside edge of the wheel i only have about 5mm of clearence between the wheel and my prostreets. I'm not sure if you can use camber plates in conjuction with air ride but that would help out alot if you did end up being really close. If you go with anything lower then a 40mm offset those wheels are going to stick out way to far. I would allways go with a higher offset because then if you run into any problems you can correct them alittle bit by getting some thin wheels spacers.
