I no every one says weld mounts in an automatic to do a 5 speed swap but would it be possible to make a bracket that bolts the manual to the auto mount?
No... There is not enough clearance, you must switch the frame brackets.
-Aaron
www.TurboTechRacing.com
![](http://registry.gmenthusiast.com/images/turbotechracing/personal_pic.jpg)
u said it couldnt be done but ive done it ya u have to use the 5 speed mounts but u can make a bolt in mount if it fails after i finish the swap i appoligize but im pretty confident that it wont
jared jones wrote:u said it couldnt be done but ive done it ya u have to use the 5 speed mounts but u can make a bolt in mount if it fails after i finish the swap i appoligize but im pretty confident that it wont
He said you can't make a mount that bolts to the auto mount.
That's obviously not what you did.
